Conduit Sizing Calculator command
Command |
Path |
Conduit Sizing Calc |
AEC > Electrical |
The Conduit Sizing Calculator reports the proper size conduit required for a given set of wires.
To perform conduit sizing calculations:
Select the command.
The Conduit Sizing Calculator dialog box opens.
Parameter |
Description |
Conductor Item |
Type/Manufacturer |
Using the information contained in the wire specifications database, select a wire type or manufacturer |
Size/Part Number |
Select a wire size or part number |
Number of conductors |
Enter the number of conductors of this type and size |
C-S Area of conductor in sq inches |
The cross-sectional area of the specified conductor displays |
Add >> |
Click to include the specified conductors in the conduit |
Remove |
Click to removed a selected conductor from the Conductors Currently in Conduit list |
Clear All |
Click to remove all conductors from the Conductors Currently in Conduit list |
Conductors Currently in Conduit |
Displays a list of conductors currently included in the conduit |
Conduit Type |
Select a conduit type |
Number of conduits |
Specify the number of conduits |
Conduit stuff percentage |
Specify a conduit stuff percentage; the percentage suggested by the software can be modified |
Results |
Actual Conduit Size required in inches/mm |
Displays the actual size of conduit required |
Nominal Conduit (Trade) size required in inches/mm |
Displays the nominal (trade) size of conduit required |
When calculations are complete, click Close.
